Saltar al contenido principal
Nokia N900 Camera Replacement
Qué necesitas
  1. Nokia N900 Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
  2. Nokia N900 Camera Replacement: paso 2, imagen 1 de 1
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
  3. Nokia N900 Camera Replacement: paso 3, imagen 1 de 1
    • Remove the battery
  4. Nokia N900 Camera Replacement: paso 4, imagen 1 de 1
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
  5. Nokia N900 Camera Replacement: paso 5, imagen 1 de 1
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
  6. Nokia N900 Camera Replacement: paso 6, imagen 1 de 1
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
  7. Nokia N900 Camera Replacement: paso 7, imagen 1 de 1
    • Here are the two main pieces of the camera.
  8. Nokia N900 Camera Replacement: paso 8, imagen 1 de 1
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
Conclusión
Una persona más ha completado esta guía.
Juan Haro
Miembro Desde 03/13/14
284 Reputación
2 Guías creadas
Equipo
Un comentario
Where to find a camera part ?
Thanks
François Soltic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,196
