Partes
No se requieren partes.
  1. Orient the phone as shown.
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Remove the battery cover by lifting it away from the phone.
    • Remove the battery cover by lifting it away from the phone.
  3. Insert the plastic opening tool into the marked space.
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the battery from the phone.
    • Remove the battery from the phone.
  6. Insert the plastic opening tool in the marked areas in between the front and back covers. Pry each corner with the plastic opening tool until the front case completely detaches. Pry each corner with the plastic opening tool until the front case completely detaches.
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  7. Orient the phone so that the keypad is facing you. Remove the keypad by lifting it away from the phone. Remove the keypad by lifting it away from the phone.
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  8. Use the T6 Torx screwdriver to remove the six 15 mm Torx screws. Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
    • Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
  9. Lift the bottom edge of the front panel at a 45 degree angle. Remove front panel by slowly pulling it away from the phone at a 45 degree angle. Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
    • Lift the bottom edge of the front panel at a 45 degree angle.
    • Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
  10. Locate the speaker location located on the back panel of the phone. Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located Slowly lift speaker away from the back panel.
    • Locate the speaker location located on the back panel of the phone.
    • Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
    • Slowly lift speaker away from the back panel.
Conclusión
Justin
Miembro Desde 12/10/11
933 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-2, Regan Fall 2011 Miembro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Miembros
10 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 7
Todo El Tiempo: 3,787
