Saltar al contenido principal
Nokia N70 Back Camera Replacement
Qué necesitas
  1. Nokia N70 Back Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Back Camera Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Back Camera Replacement: paso 3, imagen 1 de 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Back Camera Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the phone.
  5. Nokia N70 Back Camera Replacement, Keypad: paso 5, imagen 1 de 3 Nokia N70 Back Camera Replacement, Keypad: paso 5, imagen 2 de 3 Nokia N70 Back Camera Replacement, Keypad: paso 5, imagen 3 de 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Back Camera Replacement: paso 6, imagen 1 de 3 Nokia N70 Back Camera Replacement: paso 6, imagen 2 de 3 Nokia N70 Back Camera Replacement: paso 6, imagen 3 de 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Back Camera Replacement, Back Camera: paso 7, imagen 1 de 2 Nokia N70 Back Camera Replacement, Back Camera: paso 7, imagen 2 de 2
    • Using T6 Torx screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Back Camera Replacement: paso 8, imagen 1 de 3 Nokia N70 Back Camera Replacement: paso 8, imagen 2 de 3 Nokia N70 Back Camera Replacement: paso 8, imagen 3 de 3
    • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
    • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
  9. Nokia N70 Back Camera Replacement: paso 9, imagen 1 de 3 Nokia N70 Back Camera Replacement: paso 9, imagen 2 de 3 Nokia N70 Back Camera Replacement: paso 9, imagen 3 de 3
    • Locate the rear circuit board by flipping over the front panel.
    • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
    • Caution: Be careful when prying camera out of the slot for the connections are fragile.
Conclusión
5 personas más completaron esta guía.
Justin
Miembro Desde 10/12/11
984 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-2, Regan Fall 2011 Miembro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
Miembros de 4
11 Guías creadas
Un comentario
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 8,922
