Introducción
By reading this guide you will have a better understanding of how to disassemble your phone so as to reach the vibration module located directly behind the daughter engine board.
Qué necesitas
Use the flat end of a spudger to disconnect the camera connectors.
Pull the camera up and out to remove it from the phone.
Use the pointed end of the spudger to pry up the daughterboard.
Use tweezers to lift the daughterboard out of the phone.
Use a pair of tweezers to remove the vibration boot that covers the module.
Una persona más ha completado esta guía.
