Introducción
If the display on your Nokia Lumia 930 does not light up, or is severely damaged, use this guide to replace it! Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Qué necesitas
Use the flat end of a spudger to disconnect the camera connectors.
Pull the camera up and out to remove it from the phone.
Place a suction cup in the center of the screen, then pry the display away from the frame.
2 personas más completaron esta guía.
