Saltar al contenido principal
Nokia Lumia 930 Battery Replacement
Qué necesitas
  1. Nokia Lumia 930 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Battery Replacement: paso 2, imagen 1 de 2 Nokia Lumia 930 Battery Replacement: paso 2, imagen 2 de 2
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Battery Replacement: paso 3, imagen 1 de 2 Nokia Lumia 930 Battery Replacement: paso 3, imagen 2 de 2
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Battery Replacement: paso 5, imagen 1 de 1
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Battery Replacement: paso 6, imagen 1 de 2 Nokia Lumia 930 Battery Replacement: paso 6, imagen 2 de 2
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Battery Replacement: paso 7, imagen 1 de 3 Nokia Lumia 930 Battery Replacement: paso 7, imagen 2 de 3 Nokia Lumia 930 Battery Replacement: paso 7, imagen 3 de 3
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Battery Replacement: paso 8, imagen 1 de 1
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Battery Replacement: paso 9, imagen 1 de 1
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Battery Replacement: paso 10, imagen 1 de 1
    • Remove the battery from the phone.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 31
Todo El Tiempo: 5,703
