Saltar al contenido principal
Nokia Lumia 900 Battery Replacement
Qué necesitas
  1. Nokia Lumia 900 Battery Replacement, Screen: paso 1, imagen 1 de 2 Nokia Lumia 900 Battery Replacement, Screen: paso 1, imagen 2 de 2
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Battery Replacement: paso 2, imagen 1 de 2 Nokia Lumia 900 Battery Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Battery Replacement: paso 3, imagen 1 de 2 Nokia Lumia 900 Battery Replacement: paso 3, imagen 2 de 2
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Battery Replacement: paso 4, imagen 1 de 2 Nokia Lumia 900 Battery Replacement: paso 4, imagen 2 de 2
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
  6. Nokia Lumia 900 Battery Replacement, Battery: paso 6, imagen 1 de 2 Nokia Lumia 900 Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Use the flat end of a spudger to carefully disconnect the ribbon cable.
    • Make sure not to bend or crease the cable.
  7. Nokia Lumia 900 Battery Replacement: paso 7, imagen 1 de 2 Nokia Lumia 900 Battery Replacement: paso 7, imagen 2 de 2
    • Use the flat end of a spudger to remove the battery.
    • The battery may be glued down. This will be evident if the battery is difficult to lift. Use the iFixit iOpener to heat the back of the phone allowing the glue to heat and become more pliable before trying to lift the battery again. This may take several minutes.
Conclusión
Kourtney Collier
Miembro Desde 03/31/22
289 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Spring 2022 Miembro de IUPUI, Team 3-2, Harley Spring 2022
IUPUI-HARLEY-S22S3G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 337
