Saltar al contenido principal
Nokia Lumia 830 Battery Replacement
Qué necesitas
  1. Nokia Lumia 830 Battery Replacement, Battery: paso 1, imagen 1 de 2 Nokia Lumia 830 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Place the phone with the screen facing down.
    • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
  2. Nokia Lumia 830 Battery Replacement: paso 2, imagen 1 de 3 Nokia Lumia 830 Battery Replacement: paso 2, imagen 2 de 3 Nokia Lumia 830 Battery Replacement: paso 2, imagen 3 de 3
    • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
    • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
Conclusión
Adam Mack
Miembro Desde 10/04/16
284 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-2, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G2
3 Miembros
11 Guías creadas
Un comentario
Hi, i’ve bought a battery from amazon to this phone. It has the same specs as the old one, but when i put it to charge (on the phone) it only charges untill half and it stays there. Do i need to buy a different battery or is there a way to fix this?
Eduardo Teixeira - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,421
