Qué necesitas
Stick your opening pick between the plastic casing and the screen
Move your pick up toward the top corner of the phone
Rotate the pick so it is parallel with the back of the phone
Move the pick in between the back of the phone and the plastic cover to the top left corner
Use the gap made by the pick between the back plastic and the phone to pry apart the two parts
The back should now be removed exposing the battery, SIM card, and SD card on the back of the phone
Insert the pick into the opening near the top of the battery
Use the pick to lift up the battery until you can remove it from its resting place
The battery should now be removed from the phone
Insert the new battery bottom first, lining up the connectors on the battery with the connectors on the phone
Slide the battery in and push it down so it stays in its place
Line up the back with the back of the phone
Push down on the back until you hear it snap into place
Congratulations! You just replaced the battery on your phone, you may turn it back on and begin using it normally.
