Introducción
Nokia Lumia 720 Display Assembly Replacement - Touch Screen Glass and LCD Display.
Qué necesitas
Resumen del Video
Remove the SIM card tray and the memory card try.
Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
Use plastic tools and start the separating the back cover from the top side.
Disconnect the battery flex cable.
Unstick the metal foil from the logic board.
Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
Disconnect the Volume, Power and camera buttons flex cable.
Remove the 4x Torx T4 screws.
Slightly lift the board
Use a hair dryer and warm the flex cable.
Careful unstuck the flex cable from the middle frame.
Micro USB connector
Microphone
Now you can start with the reassembling, but before you place the back cover, test the new display assembly.
5 personas más completaron esta guía.
