Introducción
Nokia Lumia 720 - How to remove and replace the Battery.
Qué necesitas
Resumen del Video
Remove the SIM card tray and the memory card try.
Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
Use plastic tools and start the separating the back cover from the top side.
Disconnect the battery flex cable.
Unstick the metal foil from the logic board.
Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
Una persona más ha completado esta guía.
3 comentarios
I have nokia lumia 720....it can't starting up only shows charging sing..... plz...help me
i have also the same problem is ur problem fixed now ..then pls tell me the solution
Hey guys I really need to know if you can recommend a trusted retailer of spare BP-4GWA here in South East Asia. I am currently residing in the Philippines and it's just hard to buy from Ebay and Alibaba without anyone's opinion. TIA!
