Saltar al contenido principal
Nokia Lumia 635 Display Assembly Replacement
Qué necesitas
Resumen del Video
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: paso 1, imagen 1 de 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: paso 1, imagen 2 de 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: paso 1, imagen 3 de 3
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: paso 2, imagen 1 de 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: paso 2, imagen 2 de 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: paso 2, imagen 3 de 3
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: paso 3, imagen 1 de 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: paso 3, imagen 2 de 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: paso 3, imagen 3 de 3
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
  4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: paso 4, imagen 1 de 3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: paso 4, imagen 2 de 3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: paso 4, imagen 3 de 3
    • Insert wisdom here.
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: paso 5, imagen 1 de 2 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: paso 5, imagen 2 de 2
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
  6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: paso 6, imagen 1 de 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: paso 6, imagen 2 de 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: paso 6, imagen 3 de 3
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
  7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: paso 7, imagen 1 de 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: paso 7, imagen 2 de 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: paso 7, imagen 3 de 3
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
  8. Nokia Lumia 635 Display Assembly Replacement: paso 8, imagen 1 de 2 Nokia Lumia 635 Display Assembly Replacement: paso 8, imagen 2 de 2
    • That's all.
    • Did you do it successfully?
Conclusión
5 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,182 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,521 Guías creadas
2 comentarios
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - Contestar
how to fix the display
Roneil Mcintosh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 9,814
