Saltar al contenido principal
Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
Qué necesitas
Resumen del Video
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: paso 1, imagen 1 de 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: paso 1, imagen 2 de 2
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 2, imagen 1 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 2, imagen 2 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 2, imagen 3 de 3
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 3, imagen 1 de 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 3, imagen 2 de 2
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 4, imagen 1 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 4, imagen 2 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 4, imagen 3 de 3
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 5, imagen 1 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 5, imagen 2 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 5, imagen 3 de 3
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 6, imagen 1 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 6, imagen 2 de 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 6, imagen 3 de 3
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: paso 7, imagen 1 de 1
    • That's all.
    • Did you do it successfully?
Conclusión
4 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,368 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,465 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,882
