Introducción
The audio jack is the part of the phone with the circular opening right above the motherboard. After the battery and motherboard have been removed, the audio jack can be easily removed.
Qué necesitas
Push the plastic opening tool in between the screen and the back case of the phone.
Pry the top of the phone between the case and screen until they are separated.
After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
Using the Torx T5 screw head, remove all screws. Note that there are two different sized screws. Five screws are 5 mm long and four are 4 mm long.
Five 5 mm screws.
Four 4 mm screws.
Gently pry audio jack with your hand until it is removed from its space on the phone.
Una persona más ha completado esta guía.
