Saltar al contenido principal
Nokia Lumia 521 Ear Speaker
Qué necesitas
  1. Nokia Lumia 521 Ear Speaker, Battery: paso 1, imagen 1 de 2 Nokia Lumia 521 Ear Speaker, Battery: paso 1, imagen 2 de 2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Ear Speaker: paso 2, imagen 1 de 1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 Ear Speaker, SIM Card: paso 3, imagen 1 de 1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
  4. Nokia Lumia 521 Ear Speaker, Motherboard: paso 4, imagen 1 de 2 Nokia Lumia 521 Ear Speaker, Motherboard: paso 4, imagen 2 de 2
    • Using the Torx T5 screw head, remove all screws. Note that there are two different sized screws. Five screws are 5 mm long and four are 4 mm long.
    • Five 5 mm screws.
    • Four 4 mm screws.
  5. Nokia Lumia 521 Ear Speaker: paso 5, imagen 1 de 2 Nokia Lumia 521 Ear Speaker: paso 5, imagen 2 de 2
    • Using a plastic opening tool, pry apart the inner back case apart from the rest of the phone, starting at the top and prying while going around the phone.
  6. Nokia Lumia 521 Ear Speaker: paso 6, imagen 1 de 2 Nokia Lumia 521 Ear Speaker: paso 6, imagen 2 de 2
    • Unclasp the motherboard from the black case clasps using a plastic opening tool.
  7. Nokia Lumia 521 Ear Speaker: paso 7, imagen 1 de 2 Nokia Lumia 521 Ear Speaker: paso 7, imagen 2 de 2
    • Unclip the motherboard clasps using your fingers or a plastic opening tool.
  8. Nokia Lumia 521 Ear Speaker, Ear Speaker: paso 8, imagen 1 de 1
    • Carefully lift the tabs on the side of the ear speaker with the plastic opening tool
    • The speaker is securely attached to the device so some force is necessary to remove the speaker. Be careful not to use too much force as you do not want to cause any damage to the phone.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 2-4, Sullivan Spring 2016 Miembro de USF Tampa, Team 2-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 227
