Saltar al contenido principal
Nokia Lumia 520 Battery Replacement
Qué necesitas
  1. Nokia Lumia 520 Battery Replacement, Battery: paso 1, imagen 1 de 2 Nokia Lumia 520 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: paso 2, imagen 1 de 2 Nokia Lumia 520 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Battery Replacement: paso 3, imagen 1 de 2 Nokia Lumia 520 Battery Replacement: paso 3, imagen 2 de 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
Conclusión
2 personas más completaron esta guía.
Kobina Faibille
Miembro Desde 11/03/15
156 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Miembro de UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 Miembros
8 Guías creadas
Un comentario
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 27
Todo El Tiempo: 3,384
