Saltar al contenido principal
Nokia Lumia 520 Audio Jack Replacement
Qué necesitas
  1. Nokia Lumia 520 Audio Jack Replacement, Battery: paso 1, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Audio Jack Replacement: paso 2, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement: paso 2, imagen 2 de 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Audio Jack Replacement: paso 3, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement: paso 3, imagen 2 de 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Audio Jack Replacement, Audio Jack: paso 4, imagen 1 de 3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: paso 4, imagen 2 de 3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: paso 4, imagen 3 de 3
    • Unscrew the 8 screws with a Torx screw driver (T4) and make sure you know what screws went where because they are different.
  5. Nokia Lumia 520 Audio Jack Replacement: paso 5, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement: paso 5, imagen 2 de 2
    • Use your plastic spudger to remove the clips on the plastic casing over the motherboard. Note there are 10 clips holding the casing on(3 on the sides, 2 on the top and bottom).
  6. Nokia Lumia 520 Audio Jack Replacement: paso 6, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement: paso 6, imagen 2 de 2
    • Carefully unclip the digitizer touch screen cable and the display screen cable using the spudger.
  7. Nokia Lumia 520 Audio Jack Replacement: paso 7, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement: paso 7, imagen 2 de 2
    • Gently remove the motherboard.
  8. Nokia Lumia 520 Audio Jack Replacement: paso 8, imagen 1 de 2 Nokia Lumia 520 Audio Jack Replacement: paso 8, imagen 2 de 2
    • Use the plastic spudger and gently remove the audio jack and the flex connector to the audio jack away from the case.
    • You will feel some pressure since the audio jack is held in place with two sided tape.
Conclusión
5 personas más completaron esta guía.
Tyler Chellis
Miembro Desde 11/03/15
249 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Miembro de UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
Miembros de 3
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,743
