Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nokia Lumia 2520 Display Assembly Replacement
Qué necesitas
  1. Nokia Lumia 2520 Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Apply heat pad to each side of the device.
    • When using any heat pad please use some form of padded gloves so you don't burn you fingers.
    • Microwave the pad for 30 seconds so an ample amount of heat is given on all four sides. Do not microwave more than once every two minutes.
  2. Nokia Lumia 2520 Display Assembly Replacement: paso 2, imagen 1 de 3 Nokia Lumia 2520 Display Assembly Replacement: paso 2, imagen 2 de 3 Nokia Lumia 2520 Display Assembly Replacement: paso 2, imagen 3 de 3
    • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
    • When pulling the screen off the chassis, be careful not to cut the ribbon cable that connects the screen to the logic board.
    • Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
  3. Nokia Lumia 2520 Display Assembly Replacement: paso 3, imagen 1 de 2 Nokia Lumia 2520 Display Assembly Replacement: paso 3, imagen 2 de 2
    • Pull the ribbon cable out from the connection port on the board.
    • Move on the step 4 to remove the ribbon connection from the screen.
  4. Nokia Lumia 2520 Display Assembly Replacement: paso 4, imagen 1 de 3 Nokia Lumia 2520 Display Assembly Replacement: paso 4, imagen 2 de 3 Nokia Lumia 2520 Display Assembly Replacement: paso 4, imagen 3 de 3
    • Use the plastic pry tool to remove both of the connections.
  5. Nokia Lumia 2520 Display Assembly Replacement: paso 5, imagen 1 de 1
    • Set aside the screen and the display assembly for repair.
Conclusión
Daniel Chevalier
Miembro Desde 09/05/18
121 Reputación
1 Guía escrita
Equipo
Gateway, Team S1-G4, Luster Fall 2018 Miembro de Gateway, Team S1-G4, Luster Fall 2018
GCC-LUSTER-F18S1G4
Miembros de 5
5 Guías creadas
1Guía Comentario
What if i clipped the ribbon cable step 2 told me not to... like in half? Springging for a new screen i assume. Ive repaired ribbons before and it doesnt look like theres enough cable left to splice.
Hunter - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 1,314
