Saltar al contenido principal
Nokia Lumia 1020 Rear-Facing Camera Replacement
Qué necesitas
  1. Nokia Lumia 1020 Rear-Facing Camera Replacement, Screen: paso 1, imagen 1 de 2 Nokia Lumia 1020 Rear-Facing Camera Replacement, Screen: paso 1, imagen 2 de 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 2, imagen 1 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 2, imagen 2 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 2, imagen 3 de 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 3, imagen 1 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 3, imagen 2 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 3, imagen 3 de 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 4, imagen 1 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 4, imagen 2 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: paso 4, imagen 3 de 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
  5. Nokia Lumia 1020 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 5, imagen 1 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 5, imagen 2 de 3 Nokia Lumia 1020 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 5, imagen 3 de 3
    • Use your fingernail to grip the rear-facing camera on the upper middle part of the back of the phone. Pry until it pops off to the left.
    • Remove the camera by wedging a spudger underneath the attached gold foil.
Conclusión
Equipo
USF Tampa, Team S1-G4, Leahy Spring 2018 Miembro de USF Tampa, Team S1-G4, Leahy Spring 2018
USFT-LEAHY-S18S1G4
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 980
