Saltar al contenido principal
Nokia Lumia 1020 Motherboard Replacement
Qué necesitas
  1. Nokia Lumia 1020 Motherboard Replacement, Screen: paso 1, imagen 1 de 2 Nokia Lumia 1020 Motherboard Replacement, Screen: paso 1, imagen 2 de 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Motherboard Replacement: paso 2, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 2, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 2, imagen 3 de 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Motherboard Replacement: paso 3, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 3, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 3, imagen 3 de 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Motherboard Replacement: paso 4, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 4, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 4, imagen 3 de 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
  5. Nokia Lumia 1020 Motherboard Replacement, Battery: paso 5, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement, Battery: paso 5, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement, Battery: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Unscrew the two 4 mm torx screws on the top silver strip with a T4 screwdriver.
    • Unscrew the 4.5 mm torx screw above the gold bar with a T6 screwdriver.
    • Grab the edges of the gold strip with gripped tweezers to remove. The gold and silver metal will come off together.
  6. Nokia Lumia 1020 Motherboard Replacement: paso 6, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 6, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 6, imagen 3 de 3
    • Be careful not to puncture the battery. Use a spudger to slice the black tape on the left side of the battery.
    • Remove the battery with your finger.
    • Wedge a spudger underneath the small black rectangle attached to the battery until it pops off.
  7. Nokia Lumia 1020 Motherboard Replacement, Headphone Jack: paso 7, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement, Headphone Jack: paso 7, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement, Headphone Jack: paso 7, imagen 3 de 3
    • Use the T4 screwdriver to remove the 4 mm torx screw.
    • Remove the headphone jack by pulling back on the silver plate with your fingernail.
  8. Nokia Lumia 1020 Motherboard Replacement: paso 8, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 8, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the headphone jack with spudger.
    • Wedge the spudger underneath the grey rectangle and pry until it pops off. Note this piece is glued and may require more force than previous rectangles.
    • Headphone jack is fully removed and can be replaced.
  9. Nokia Lumia 1020 Motherboard Replacement, Rear-Facing Camera: paso 9, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement, Rear-Facing Camera: paso 9, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement, Rear-Facing Camera: paso 9, imagen 3 de 3
    • Use your fingernail to grip the rear-facing camera on the upper middle part of the back of the phone. Pry until it pops off to the left.
    • Remove the camera by wedging a spudger underneath the attached gold foil.
  10. Nokia Lumia 1020 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 Nokia Lumia 1020 Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • Disconnect the two gold connectors from the motherboard using a spudger.
    • Be gentle with the connectors to make sure they are not damaged.
  11. Nokia Lumia 1020 Motherboard Replacement: paso 11, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 11, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 11, imagen 3 de 3
    • Using a T4 screwdriver, remove four 4.60 mm screws to disconnect the motherboard from the rest of the device.
    • Be sure not to lose the screws.
  12. Nokia Lumia 1020 Motherboard Replacement: paso 12, imagen 1 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 12, imagen 2 de 3 Nokia Lumia 1020 Motherboard Replacement: paso 12, imagen 3 de 3
    • Use the spudger to remove motherboard first from the top right corner, then bottom right corner, then the bottom left corner.
    • After loosening the motherboard, begin to remove the component by starting at the top right corner first, then pull motherboard out.
Conclusión
Abbi Waterfill
Miembro Desde 11/04/19
354 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G5, Henning Fall 2019 Miembro de IUPUI, Team S1-G5, Henning Fall 2019
IUPUI-HENNING-F19S1G5
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 1,080
