Saltar al contenido principal
Nokia E90 QWERTY Keyboard Replacement
Qué necesitas
  1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: paso 1, imagen 1 de 1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 QWERTY Keyboard Replacement: paso 2, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 2, imagen 2 de 2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 QWERTY Keyboard Replacement: paso 3, imagen 1 de 1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
  4. Nokia E90 QWERTY Keyboard Replacement, Back Cover: paso 4, imagen 1 de 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: paso 4, imagen 2 de 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: paso 4, imagen 3 de 3
    • Using a plastic opening tool, separate the back cover from the phone.
  5. Nokia E90 QWERTY Keyboard Replacement: paso 5, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 5, imagen 2 de 2
    • Continue along the edge with the plastic opening tool.
  6. Nokia E90 QWERTY Keyboard Replacement: paso 6, imagen 1 de 3 Nokia E90 QWERTY Keyboard Replacement: paso 6, imagen 2 de 3 Nokia E90 QWERTY Keyboard Replacement: paso 6, imagen 3 de 3
    • Gently, remove the back cover.
  7. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: paso 7, imagen 1 de 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: paso 7, imagen 2 de 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: paso 7, imagen 3 de 3
    • Unscrew the indicated screws using the T5 screwdriver.
  8. Nokia E90 QWERTY Keyboard Replacement: paso 8, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 8, imagen 2 de 2
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
  9. Nokia E90 QWERTY Keyboard Replacement: paso 9, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 9, imagen 2 de 2
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
  10. Nokia E90 QWERTY Keyboard Replacement: paso 10, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 10, imagen 2 de 2
    • With the T5 Screwdriver, remove the marked screws.
  11. Nokia E90 QWERTY Keyboard Replacement: paso 11, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 11, imagen 2 de 2
    • With the screws removed, the sensor board should be free to flip up.
  12. Nokia E90 QWERTY Keyboard Replacement: paso 12, imagen 1 de 2 Nokia E90 QWERTY Keyboard Replacement: paso 12, imagen 2 de 2
    • Disconnect the wire with the plastic opening tool.
  13. Nokia E90 QWERTY Keyboard Replacement: paso 13, imagen 1 de 3 Nokia E90 QWERTY Keyboard Replacement: paso 13, imagen 2 de 3 Nokia E90 QWERTY Keyboard Replacement: paso 13, imagen 3 de 3
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 18-21, Garner Spring 2011 Miembro de Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 19
Todo El Tiempo: 6,464
