Saltar al contenido principal
Nokia E71x Camera Flash Replacement
Qué necesitas
  1. Nokia E71x Camera Flash Replacement, Motherboard: paso 1, imagen 1 de 2 Nokia E71x Camera Flash Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove battery
  2. Nokia E71x Camera Flash Replacement: paso 2, imagen 1 de 1
    • Using Torx number 4 unscrew the four 0.5mm screws.
  3. Nokia E71x Camera Flash Replacement: paso 3, imagen 1 de 1
    • Push in four clips to detach the body.
  4. Nokia E71x Camera Flash Replacement: paso 4, imagen 1 de 3 Nokia E71x Camera Flash Replacement: paso 4, imagen 2 de 3 Nokia E71x Camera Flash Replacement: paso 4, imagen 3 de 3
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
  5. Nokia E71x Camera Flash Replacement: paso 5, imagen 1 de 3 Nokia E71x Camera Flash Replacement: paso 5, imagen 2 de 3 Nokia E71x Camera Flash Replacement: paso 5, imagen 3 de 3
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
  6. Nokia E71x Camera Flash Replacement: paso 6, imagen 1 de 1
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  7. Nokia E71x Camera Flash Replacement: paso 7, imagen 1 de 2 Nokia E71x Camera Flash Replacement: paso 7, imagen 2 de 2
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  8. Nokia E71x Camera Flash Replacement: paso 8, imagen 1 de 1
    • Replace motherboard, ensure that replacement has the same serial number.
  9. Nokia E71x Camera Flash Replacement, Camera Flash: paso 9, imagen 1 de 1
    • Camera is located on back of camera body.
    • To remove flash turn body over and gently tap on the case. The flash should fall out.
Conclusión
2 personas más completaron esta guía.
Will Goldby
Miembro Desde 08/29/11
187 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-1, Zipperian Fall 2011 Miembro de Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,070
