Saltar al contenido principal
Nokia E71x Battery Replacement
  1. Nokia E71x Battery Replacement, Battery: paso 1, imagen 1 de 2 Nokia E71x Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use your fingers to lift the battery out of the phone.
Conclusión
Once the new battery is securely installed, you are ready to put your phone back together. Simply reverse the steps you followed to disassemble your Nokia E71x. Make sure all components fit snugly back into their places. Power on your device to ensure everything is working correctly. Congratulations on successfully replacing your battery! Your Nokia E71x should now be ready.
Una persona más ha completado esta guía.
Will Goldby
Miembro Desde 08/29/11
187 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-1, Zipperian Fall 2011 Miembro de Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
Miembros de 3
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,151
