Saltar al contenido principal
Nokia E61i Front Cover Replacement
Qué necesitas
  1. Nokia E61i Front Cover Replacement, Battery: paso 1, imagen 1 de 2 Nokia E61i Front Cover Replacement, Battery: paso 1, imagen 2 de 2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Nokia E61i Front Cover Replacement: paso 2, imagen 1 de 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Front Cover Replacement: paso 3, imagen 1 de 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Front Cover Replacement, Front Cover: paso 4, imagen 1 de 2 Nokia E61i Front Cover Replacement, Front Cover: paso 4, imagen 2 de 2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Front Cover Replacement: paso 5, imagen 1 de 1
    • Remove the cover by pulling it up and off.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 9-63, Walters Spring 2011 Miembro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
Miembros de 5
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,909
