Saltar al contenido principal
Nokia Classic 2600c-2b Camera Replacement
Qué necesitas
  1. Nokia Classic 2600c-2b Camera Replacement, Camera: paso 1, imagen 1 de 2 Nokia Classic 2600c-2b Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Camera Replacement: paso 2, imagen 1 de 1
    • Remove the back cover to expose the battery. Put the plastic cover in a safe location for later.
  3. Nokia Classic 2600c-2b Camera Replacement: paso 3, imagen 1 de 2 Nokia Classic 2600c-2b Camera Replacement: paso 3, imagen 2 de 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out by putting your finger in the small indent.
  4. Nokia Classic 2600c-2b Camera Replacement: paso 4, imagen 1 de 2 Nokia Classic 2600c-2b Camera Replacement: paso 4, imagen 2 de 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Camera Replacement: paso 5, imagen 1 de 1
    • Remove the faceplate with the number pad attached and put the faceplate to the side.
  6. Nokia Classic 2600c-2b Camera Replacement: paso 6, imagen 1 de 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Camera Replacement: paso 7, imagen 1 de 2 Nokia Classic 2600c-2b Camera Replacement: paso 7, imagen 2 de 2
    • Remove the six screws along the edges of the phone using a Torx 5 screwdriver.
  8. Nokia Classic 2600c-2b Camera Replacement: paso 8, imagen 1 de 2 Nokia Classic 2600c-2b Camera Replacement: paso 8, imagen 2 de 2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Camera Replacement: paso 9, imagen 1 de 2 Nokia Classic 2600c-2b Camera Replacement: paso 9, imagen 2 de 2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell. Place the metal display in a safe location for reassembly.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Camera Replacement: paso 10, imagen 1 de 1
    • Turn the motherboard over and locate the orange ribbon tape connecting the display to the motherboard.
    • Gently pull the tape up to remove the display.
  11. Nokia Classic 2600c-2b Camera Replacement: paso 11, imagen 1 de 1
    • Locate the camera component in the plastic shell removed from underneath the motherboard (It is one piece).
    • Gently pull out the camera component using either a finger or plastic opening tool.
Conclusión
2 personas más completaron esta guía.
Ian VanZandt
Miembro Desde 02/14/12
654 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 1,255
