Saltar al contenido principal
Nokia Classic 2600c-2b Battery Replacement
Qué necesitas
  1. Nokia Classic 2600c-2b Battery Replacement, Battery: paso 1, imagen 1 de 2 Nokia Classic 2600c-2b Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Battery Replacement: paso 2, imagen 1 de 1
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Battery Replacement: paso 3, imagen 1 de 2 Nokia Classic 2600c-2b Battery Replacement: paso 3, imagen 2 de 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
    • Follow the instructions in reverse order to reassemble the phone.
Conclusión
Una persona más ha completado esta guía.
Ian VanZandt
Miembro Desde 02/14/12
654 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 720
