Saltar al contenido principal
Nokia Asha 201 Audio Jack Replacement
Qué necesitas
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: paso 1, imagen 1 de 1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: paso 2, imagen 1 de 1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: paso 3, imagen 1 de 1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: paso 4, imagen 1 de 1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: paso 5, imagen 1 de 1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: paso 6, imagen 1 de 1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: paso 7, imagen 1 de 1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: paso 8, imagen 1 de 1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Conclusión
Betsy Walker
Miembro Desde 10/10/19
157 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 192
