Saltar al contenido principal
Nokia 8390 Motherboard Replacement
Qué necesitas
  1. Nokia 8390 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Motherboard Replacement: paso 2, imagen 1 de 3 Nokia 8390 Motherboard Replacement: paso 2, imagen 2 de 3 Nokia 8390 Motherboard Replacement: paso 2, imagen 3 de 3
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Motherboard Replacement, Outer Case: paso 3, imagen 1 de 3 Nokia 8390 Motherboard Replacement, Outer Case: paso 3, imagen 2 de 3 Nokia 8390 Motherboard Replacement, Outer Case: paso 3, imagen 3 de 3
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Motherboard Replacement, Keypad: paso 4, imagen 1 de 3 Nokia 8390 Motherboard Replacement, Keypad: paso 4, imagen 2 de 3 Nokia 8390 Motherboard Replacement, Keypad: paso 4, imagen 3 de 3
    • Lightly peel the keypad off of the phone.
  5. Nokia 8390 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Nokia 8390 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Nokia 8390 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  6. Nokia 8390 Motherboard Replacement: paso 6, imagen 1 de 3 Nokia 8390 Motherboard Replacement: paso 6, imagen 2 de 3 Nokia 8390 Motherboard Replacement: paso 6, imagen 3 de 3
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  7. Nokia 8390 Motherboard Replacement: paso 7, imagen 1 de 3 Nokia 8390 Motherboard Replacement: paso 7, imagen 2 de 3 Nokia 8390 Motherboard Replacement: paso 7, imagen 3 de 3
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  8. Nokia 8390 Motherboard Replacement: paso 8, imagen 1 de 1
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
Conclusión
Clinton
Miembro Desde 10/22/12
57 Reputación
7 Guías creadas
Equipo
Clemson, Team 14-5, Benson Fall 2012 Miembro de Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 482
