Introducción
This guide shows you how to remove the charge port so that you can be sure it is functional or replace it.
Partes
No se requieren partes.
  1. Locate the button on the bottom of the back cover.
    • Locate the button on the bottom of the back cover.
  2. Depress the button with your finger. While the button is depressed, slide the back cover off of the phone. While the button is depressed, slide the back cover off of the phone.
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Grasp the top and bottom of the front cover. Grasp the phone body with your other hand. Lightly pull the casing off of the phone.
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Locate the six star-shaped screws on the phone. Note: There are two on the bottom end, two in the middle, and two on the top end. Remove these screws using the screwdriver.
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  6. Grab the top and bottom of the phone casing. Carefully pull the motherboard apart from the bottom casing. The circuit board should be divided into two parts.
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  7. Grab the top and bottom of the remaining casing. Carefully pull apart the casing from the circuit board. Carefully pull apart the casing from the circuit board.
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  8. The circuit board should be divided into three parts, completely separate from the back casing, as shown.
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
  9. Hold back of phone in hand so that hand is not covering any parts. Grasp charge port with thumb. Pull out with hand.
    • Hold back of phone in hand so that hand is not covering any parts.
    • Grasp charge port with thumb.
    • Pull out with hand.
Conclusión
2 personas más completaron esta guía.
Clinton
Miembro Desde 22/10/12
57 Reputación
7 Guías creadas
Equipo
Clemson, Team 14-5, Benson Fall 2012 Miembro de Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Miembros
16 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 225
