Saltar al contenido principal
Nokia 8265 Keypad Replacement
Qué necesitas
  1. Nokia 8265 Keypad Replacement, Keypad: paso 1, imagen 1 de 1
    • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
    • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
  2. Nokia 8265 Keypad Replacement: paso 2, imagen 1 de 1
    • Once popped off, remove the faceplate entirely, exposing the keypad.
  3. Nokia 8265 Keypad Replacement: paso 3, imagen 1 de 1
    • You can pick up the keypad with ease, as it is not attached to the phone itself.
  4. Nokia 8265 Keypad Replacement: paso 4, imagen 1 de 1
    • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
Conclusión
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Jack
Miembro Desde 04/20/12
1 Reputación
4 Guías creadas
Equipo
SUNY Cortland, Team 1-1, Getto Spring 2012 Miembro de SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 817
