Saltar al contenido principal
  1. Start by removing the face plate of the phone with a plastic tool.
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Once the face plate is off, you will have exposed the keypad.
    • Once the face plate is off, you will have exposed the keypad.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  5. Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  6. Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
  7. Now you have successfully removed the display screen and keyboard.
    • Now you have successfully removed the display screen and keyboard.
Linea de Meta
Una persona más ha completado esta guía.
Jack
Miembro Desde 20/04/12
1 Reputación
4 Guías creadas
Equipo
SUNY Cortland, Team 1-1, Getto Spring 2012 Miembro de SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 836
