Saltar al contenido principal
Nokia 8260 LCD Replacement
Qué necesitas
  1. Nokia 8260 LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the cell phone.
  2. Nokia 8260 LCD Replacement: paso 2, imagen 1 de 1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 LCD Replacement: paso 3, imagen 1 de 1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 LCD Replacement: paso 4, imagen 1 de 1
    • Remove the back cover.
  5. Nokia 8260 LCD Replacement: paso 5, imagen 1 de 1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 LCD Replacement: paso 6, imagen 1 de 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 LCD Replacement, Antenna: paso 7, imagen 1 de 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 LCD Replacement: paso 8, imagen 1 de 1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 LCD Replacement: paso 9, imagen 1 de 1
    • Remove the antenna door.
  10. Nokia 8260 LCD Replacement: paso 10, imagen 1 de 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 LCD Replacement, Circuit Board: paso 11, imagen 1 de 1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 LCD Replacement: paso 12, imagen 1 de 1
    • Remove the back covering.
  13. Nokia 8260 LCD Replacement: paso 13, imagen 1 de 1
    • Remove the two screws at the top.
  14. Nokia 8260 LCD Replacement: paso 14, imagen 1 de 1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 LCD Replacement, LCD: paso 15, imagen 1 de 1
    • Detach the LCD from the logic board at the four metal hinges.
    • There are three pieces to the LCD: the front metal border, the LCD unit, and the plastic backing. Unless you are replacing the LCD, do not separate these three pieces.
Conclusión
Aaron Jen
Miembro Desde 04/11/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 27-94, Amido Spring 2010 Miembro de Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,893
