Saltar al contenido principal
Nokia 6590i Logic Board Replacement
Qué necesitas
  1. Nokia 6590i Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Before taking apart your Nokia 6590i, you will need to purchase a new battery. You can find them at Amazon, Walmart, or any cell phone repair store.
    • For reference, pictured here is a photo of a new battery for the Nokia 6590i.
    • Most new batteries will have a price range of $10 to $30.
  2. Nokia 6590i Logic Board Replacement: paso 2, imagen 1 de 2 Nokia 6590i Logic Board Replacement: paso 2, imagen 2 de 2
    • After purchasing a new battery, we can begin the replacement.
    • First, press the button on the bottom of the rear cover.
    • Second, keep the button pressed while pulling the cover downward to remove the back cover.
    • Third, lift the cover off.
  3. Nokia 6590i Logic Board Replacement: paso 3, imagen 1 de 1
    • Then, to remove the old battery, push it down from the top and pull it out.
    • To install the new battery, just follow this guide in reverse order!
  4. Nokia 6590i Logic Board Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 4, imagen 1 de 1
    • Grip the front cover from the bottom.
  5. Nokia 6590i Logic Board Replacement: paso 5, imagen 1 de 1
    • Lift the front cover off.
  6. Nokia 6590i Logic Board Replacement: paso 6, imagen 1 de 1
    • Remove the six screws using a T6 torx screwdriver.
  7. Nokia 6590i Logic Board Replacement: paso 7, imagen 1 de 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  8. Nokia 6590i Logic Board Replacement: paso 8, imagen 1 de 1
    • Remove assembly from phone
  9. Nokia 6590i Logic Board Replacement, Logic Board: paso 9, imagen 1 de 1
    • The logic board now sits on top of the phone.
  10. Nokia 6590i Logic Board Replacement: paso 10, imagen 1 de 1
    • Lift the logic board out of the phone.
Conclusión
Colby Leslie
Miembro Desde 10/05/10
13 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 22-3, Maness Fall 2010 Miembro de Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
Miembros de 4
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,100
