Saltar al contenido principal
Nokia 6560 keypad replacement or cleaning
Qué necesitas
  1. Nokia 6560 keypad replacement or cleaning, Battery: paso 1, imagen 1 de 2 Nokia 6560 keypad replacement or cleaning, Battery: paso 1, imagen 2 de 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 keypad replacement or cleaning: paso 2, imagen 1 de 2 Nokia 6560 keypad replacement or cleaning: paso 2, imagen 2 de 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 keypad replacement or cleaning, Keypad: paso 3, imagen 1 de 2 Nokia 6560 keypad replacement or cleaning, Keypad: paso 3, imagen 2 de 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 keypad replacement or cleaning: paso 4, imagen 1 de 2 Nokia 6560 keypad replacement or cleaning: paso 4, imagen 2 de 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
Conclusión
3 personas más completaron esta guía.
Tim Bergmann
Miembro Desde 01/18/10
35 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-17, Maness Winter 2010 Miembro de Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 2,249
