Introducción
This guide shows the procedures to replace a new keypad and clean metal button contacts for Nokia 6310i cell phone. Refer to the guides for removing the battery and separating the case from the motherboard.
Partes
No se requieren partes.
  1. Press and hold the battery release button and slide the battery away from the Nokia logo Press and hold the battery release button and slide the battery away from the Nokia logo
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Slide the SIM card lock away from the SIM card. The SIM card pops out. Remove the SIM card. The SIM card pops out. Remove the SIM card.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Unscrew and remove the four T6 Torx screws.
    • Unscrew and remove the four T6 Torx screws.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  6. Use the plastic opening tool to separate the top part of the backplate. The plastic clips at the top require slightly more force to separate. The plastic clips at the top require slightly more force to separate.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  7. Remove the screw holding the antenna to the circuit board. Carefully lift off the antenna from the circuit board.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  8. Lift off the motherboard from the faceplate.
    • Lift off the motherboard from the faceplate.
  9. Remove the plastic keypad from the faceplate. Remove the plastic keypad from the faceplate.
    • Remove the plastic keypad from the faceplate.
Conclusión
Una persona más ha completado esta guía.
Ka Siu
Miembro Desde 30/09/10
69 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-41, Forte Fall 2010 Miembro de Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 10
Todo El Tiempo: 5,061
