Saltar al contenido principal
Nokia 6200 Classic Battery Replacement
  1. Nokia 6200 Classic Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the phone so it is face down (keypad side is down).
  2. Nokia 6200 Classic Battery Replacement: paso 2, imagen 1 de 3 Nokia 6200 Classic Battery Replacement: paso 2, imagen 2 de 3 Nokia 6200 Classic Battery Replacement: paso 2, imagen 3 de 3
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Nokia 6200 Classic Battery Replacement: paso 3, imagen 1 de 3 Nokia 6200 Classic Battery Replacement: paso 3, imagen 2 de 3 Nokia 6200 Classic Battery Replacement: paso 3, imagen 3 de 3
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
Conclusión
To replace the battery, simply put a new battery in the back of the phone, and replace the back cover.
Reid Polstra
Miembro Desde 10/22/12
1 Reputación
7 Guías creadas
Equipo
Clemson, Team 15-5, Benson Fall 2012 Miembro de Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,184
