Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Use this guide to remove and replace your battery.
  1. Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone. Lift off back cover.
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
  2. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  3. Use your index finger to first push down and then lift up the battery as shown. Remove battery from cell phone. Remove battery from cell phone.
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
Conclusión
2 personas más completaron esta guía.
Vincent Benvin
Miembro Desde 19/04/10
121 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 23-82, Johann Spring 2010 Miembro de Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Miembros
5 Guías creadas
ou puis-je trouver une batterie pour un Nokia 6133? Merci
Jol Kbo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,155
