Introducción
Removing the keyboard from the Nokia 6102i
Qué necesitas
Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
Note: Images on the right side may be hovered over to reveal larger versions.
Herramienta utilizada en este paso:T6 Torx Screwdriver$9.99
Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
Pop out the keyboard from the frame.
The picture is showing the three layers: the frame, the keyboard, and the logic board.
