Saltar al contenido principal
Nokia 6086 Battery Replacement
Qué necesitas
  1. Nokia 6086 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: paso 2, imagen 1 de 3 Nokia 6086 Battery Replacement: paso 2, imagen 2 de 3 Nokia 6086 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: paso 3, imagen 1 de 3 Nokia 6086 Battery Replacement: paso 3, imagen 2 de 3 Nokia 6086 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
Conclusión
Andrea
Miembro Desde 04/15/10
70 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 26-30, Regan Spring 2010 Miembro de Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 3,833
