Saltar al contenido principal
Nokia 6085h Microphone Replacement
Qué necesitas
  1. Nokia 6085h Microphone Replacement, Battery: paso 1, imagen 1 de 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the phone's battery.
  3. Nokia 6085h Microphone Replacement, Motherboard: paso 3, imagen 1 de 2 Nokia 6085h Microphone Replacement, Motherboard: paso 3, imagen 2 de 2
    • Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
  4. Nokia 6085h Microphone Replacement: paso 4, imagen 1 de 1
    • Gently pull off the hinge cap from the top of the phone by hand.
  5. Nokia 6085h Microphone Replacement: paso 5, imagen 1 de 1
    • Use a T6 Torx screwdriver to remove the four 7.6 mm screws at the corners of the battery compartment.
  6. Nokia 6085h Microphone Replacement: paso 6, imagen 1 de 2 Nokia 6085h Microphone Replacement: paso 6, imagen 2 de 2
    • Open the phone and turn it on its side. You will see a seam around the Nokia’s side.
    • Use the iFixit opening tool to run along this seam to pop the clips holding the casing to the frame.
  7. Nokia 6085h Microphone Replacement: paso 7, imagen 1 de 1
    • Use your hand to gently pull off the back panel from the bottom half of the phone.
  8. Nokia 6085h Microphone Replacement: paso 8, imagen 1 de 1
    • Close the phone and place it on a flat surface.
    • Use the plastic opening tool or your finger to lift up the motherboard from the bottom casing.
    • Be careful when pulling up the board; there is still a ribbon cable attached to the back of the board.
  9. Nokia 6085h Microphone Replacement: paso 9, imagen 1 de 1
    • Find the underside of the motherboard and locate the ribbon cable that attaches the board to the rest of the phone. Use the plastic opening tool to slowly detach the ribbon cable connector, then pull the motherboard away from the frame.
  10. Nokia 6085h Microphone Replacement, Keypad: paso 10, imagen 1 de 1
    • Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
  11. Nokia 6085h Microphone Replacement, Microphone: paso 11, imagen 1 de 1
    • Locate the small speaker module on the back of the separated battery compartment in the lower left hand corner.
  12. Nokia 6085h Microphone Replacement: paso 12, imagen 1 de 1
    • Use the plastic opening tool to pry out the microphone from the bottom of the compartment.
Conclusión
Andrew
Miembro Desde 10/04/10
397 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 4-46, Amido Fall 2010 Miembro de Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 339
