Introducción
This guide give instructions on how to locate the inner LCD display for removal and/or repair.
Partes
No se requieren partes.
  1. Flip over the phone and then slide down the back cover with your thumb.
    • Flip over the phone and then slide down the back cover with your thumb.
  2. Lever out the battery from the phone using your thumb.
    • Lever out the battery from the phone using your thumb.
  3. With the phone closed, run a plastic opening tool along the seam of the top half of the phone Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top) Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top)
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone
    • Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top)
  4. Using T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel Note that the fourth screw is under a fold in the ribbon cable
    • Using T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel
    • Note that the fourth screw is under a fold in the ribbon cable
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down Be careful around the two ribbon cables that are attached to the tape, they are fragile Lift the tape from the board
    • Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down
    • Be careful around the two ribbon cables that are attached to the tape, they are fragile
    • Lift the tape from the board
  7. Using a plastic opening tool, lift the ribbon cable connection below the front LCD
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD
  8. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board
    • Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board
  9. Locate the ribbon cable connection in the upper right hand corner of the board
    • Locate the ribbon cable connection in the upper right hand corner of the board
    • Using a plastic opening tool, lift off the cable from the board
    • Be gentle and make sure not to rip the ribbon cable
  10. Using a plastic opening tool, slowly work the board off the mounts holding it to the frame Flip the board over to reveal the main display
    • Using a plastic opening tool, slowly work the board off the mounts holding it to the frame
    • Flip the board over to reveal the main display
  11. Locate the ribbon cable for the main display on the bottom of the board
    • Locate the ribbon cable for the main display on the bottom of the board
    • Slowly lift off the ribbon connector from its housing using a plastic opening tool
  12. Slowly wedge the plastic opening tool under the bottom of the main display Separate the display from the glue lifting it off the board
    • Slowly wedge the plastic opening tool under the bottom of the main display
    • Separate the display from the glue lifting it off the board
Conclusión
Brett Balcer
Miembro Desde 04/10/10
216 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-46, Amido Fall 2010 Miembro de Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Miembros
14 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,014
