Saltar al contenido principal
Nokia 6030 Speaker/Antenna Replacement
Qué necesitas
  1. Nokia 6030 Speaker/Antenna Replacement, Battery: paso 1, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement, Battery: paso 1, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement, Battery: paso 1, imagen 3 de 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 Speaker/Antenna Replacement: paso 2, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 2, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 2, imagen 3 de 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 Speaker/Antenna Replacement, SIM Card: paso 3, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement, SIM Card: paso 3, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement, SIM Card: paso 3, imagen 3 de 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 Speaker/Antenna Replacement: paso 4, imagen 1 de 1
    • Use your finger to close the metal cage.
  5. Nokia 6030 Speaker/Antenna Replacement, Front Cover: paso 5, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement, Front Cover: paso 5, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement, Front Cover: paso 5, imagen 3 de 3
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Nokia 6030 Speaker/Antenna Replacement: paso 6, imagen 1 de 2 Nokia 6030 Speaker/Antenna Replacement: paso 6, imagen 2 de 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 Speaker/Antenna Replacement: paso 7, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 7, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 7, imagen 3 de 3
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
  8. Nokia 6030 Speaker/Antenna Replacement, Speaker/Antenna: paso 8, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement, Speaker/Antenna: paso 8, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement, Speaker/Antenna: paso 8, imagen 3 de 3
    • Remove the six screws with a T-6 Torx screwdriver.
  9. Nokia 6030 Speaker/Antenna Replacement: paso 9, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 9, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 9, imagen 3 de 3
    • Lift the logic board and screen from the top.
    • Be careful of loose parts.
  10. Nokia 6030 Speaker/Antenna Replacement: paso 10, imagen 1 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 10, imagen 2 de 3 Nokia 6030 Speaker/Antenna Replacement: paso 10, imagen 3 de 3
    • Lift the speaker out of the back housing of the phone.
    • The speaker should come out with little effort.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 23-63, Johann Spring 2010 Miembro de Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 3,946
