Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Replacing the glass/front cover of the phone.
  1. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
    • Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Use your fingernail and gently pull the the bottom of the battery up. Lift out battery and remove. Lift out battery and remove.
    • Use your fingernail and gently pull the the bottom of the battery up.
    • Lift out battery and remove.
  3. Use your fingernail to lift the metal cage up. Remove SIM card. Remove SIM card.
    • Use your fingernail to lift the metal cage up.
    • Remove SIM card.
  4. Close the metal cage.
    • Close the metal cage.
  5. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
    • Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
  6. After removing the top cover, turn the phone over so the screen is facing upwards. After removing the top cover, turn the phone over so the screen is facing upwards.
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows.
    • Lift the front off the phone by pulling above the arrows.
Conclusión
Equipo
Cal Poly, Team 23-63, Johann Spring 2010 Miembro de Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Miembros
17 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,873
