Saltar al contenido principal
Introducción
Use this guide to remove and replace the vibrator in the Nokia 6010.
Partes
No se especificaron partes.
  1. Press the small tab on the bottom of the back of the phone. Push the back case upward towards the power button. The back case will then pop off. It requires some force, so be careful.
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Lift the battery near the bottom and pry up. Lift the battery near the bottom and pry up.
    • Lift the battery near the bottom and pry up.
  3. With one hand, press the ridged tab near the visible side of the SIM card.
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Grip the phone on either the sides, the top, or the bottom. Pull the front case away from the rest of the phone.
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Lift the keypad away from the body of the phone.
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
  7. Remove the six screws around the front of the phone body with a T6 screwdriver. Remove the six screws around the front of the phone body with a T6 screwdriver.
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
  8. Insert your finger underneath the speaker piece and pry away from the phone body. The plastic layer containing the LCD screen and speaker takes some force to remove. There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
  9. Slide the rubber power button away from the body of the phone. The power button is the rubber piece on the top of the phone.
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
  10. Insert a finger between the phone body and logic board. The logic board is the green plastic piece with circuitry attached. Pull the board away gently.
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
  11. Insert a spudger beneath the metallic shaft of the vibrator and pry it away from the phone. The vibrator is the small orange box located near the bottom of the phone. The vibrator is the small orange box located near the bottom of the phone.
    • Insert a spudger beneath the metallic shaft of the vibrator and pry it away from the phone.
    • The vibrator is the small orange box located near the bottom of the phone.
Conclusión
Equipo
Cal Poly, Team 14-45, Regan Winter 2010 Miembro de Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,103
