Introducción
Use this guide to remove and replace the charger connector in the Nokia 6010.
Qué necesitas
Press the small tab on the bottom of the back of the phone.
Push the back case upward towards the power button. The back case will then pop off.
With one hand, press the ridged tab near the visible side of the SIM card.
Slide the card out with your other hand.
Grip the phone on either the sides, the top, or the bottom.
Pull the front case away from the rest of the phone.
Remove the six screws around the front of the phone body with a T6 screwdriver.
Insert a spudger tool between the phone casing and the charger connector.
Pry the key away from the phone gently.
Una persona más ha completado esta guía.
