Saltar al contenido principal
Nokia 3360 Battery Replacement
  1. Nokia 3360 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Battery Replacement: paso 2, imagen 1 de 2 Nokia 3360 Battery Replacement: paso 2, imagen 2 de 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Battery Replacement: paso 3, imagen 1 de 2 Nokia 3360 Battery Replacement: paso 3, imagen 2 de 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 8-39, Regan Winter 2010 Miembro de Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 2,383
