Introducción
If your speaker is no longer producing sound, it may be necessary to replace the speaker altogether. This guide shows a step by step guide to fully access the speaker.
Qué necesitas
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
Use the metal spudger to leverage out the speaker.
