Saltar al contenido principal
Nokia 3310 3G Motherboard Replacement
Qué necesitas
  1. Nokia 3310 3G Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Nokia 3310 3G Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Motherboard Replacement: paso 2, imagen 1 de 2 Nokia 3310 3G Motherboard Replacement: paso 2, imagen 2 de 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Motherboard Replacement, Frame: paso 3, imagen 1 de 3 Nokia 3310 3G Motherboard Replacement, Frame: paso 3, imagen 2 de 3 Nokia 3310 3G Motherboard Replacement, Frame: paso 3, imagen 3 de 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 Nokia 3310 3G Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 Nokia 3310 3G Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Conclusión
7 personas más completaron esta guía.
Aaron LeBlanc
Miembro Desde 10/24/18
723 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 1,539
