Saltar al contenido principal
Nokia 3310 3G Keyboard Replacement
Qué necesitas
  1. Nokia 3310 3G Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Nokia 3310 3G Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Keyboard Replacement: paso 2, imagen 1 de 2 Nokia 3310 3G Keyboard Replacement: paso 2, imagen 2 de 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Keyboard Replacement, Frame: paso 3, imagen 1 de 3 Nokia 3310 3G Keyboard Replacement, Frame: paso 3, imagen 2 de 3 Nokia 3310 3G Keyboard Replacement, Frame: paso 3, imagen 3 de 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Keyboard Replacement, Motherboard: paso 4, imagen 1 de 3 Nokia 3310 3G Keyboard Replacement, Motherboard: paso 4, imagen 2 de 3 Nokia 3310 3G Keyboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Keyboard Replacement, Keyboard: paso 5, imagen 1 de 3 Nokia 3310 3G Keyboard Replacement, Keyboard: paso 5, imagen 2 de 3 Nokia 3310 3G Keyboard Replacement, Keyboard: paso 5, imagen 3 de 3
    • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
  6. Nokia 3310 3G Keyboard Replacement: paso 6, imagen 1 de 1
    • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
Conclusión
5 personas más completaron esta guía.
Aaron LeBlanc
Miembro Desde 10/24/18
723 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 Miembros
16 Guías creadas
Un comentario
Very useful and to the point
OrangeShoe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 43
Todo El Tiempo: 2,143
