Saltar al contenido principal
Introducción
How to remove the battery, and gain access to the model number sticker and screws for disassembly.
Partes
No se especificaron partes.
  1. Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool. Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. There is a molded notch in the white frame of the phone near the top right of the battery.  Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device. This specific device did not come with a battery.
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
Conclusión
Una persona más ha completado esta guía.
Taylor Lyford
Miembro Desde 24/10/18
402 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 8
Últimos 30 Días: 32
Todo El Tiempo: 339
